It's being updated every couple of days.
No problems whatsoever here, been using it since its release too.
Unless you meant that specific plugin which I haven't tried yet.
Same as
No problems like that encountered here so far and where it does work, it works well. For people who were often just on the edge of a 60fps minimum through most of the game, this final push is very evident. There has been an update to the Plugin on Skyrim Nexus that addresses some minor issues that have been reported.I'd beware of that SKSE script thing. It doesnt seem to work that well, cause's the npcs to freeze, like at the beginning of the game. After Rothgar cuts your bonds and you encouter the Imperial Captain they stop moving. Could cause other similar unknown problems. So I'm not using it at the moment.
Because that problem is caused by the ini tweaks. More distinctly it is caused by having a low fShadowDistance.My shadows are popping/fading in when I am running along and I can't remember it doing this before I am also getting a little scenery pop up, its really annoying.
Only done the config tweets(all of them) except vsync.
I'd not use the shadow ini tweaks to be honest. The gains is some areas are negated by the side effects they cause.
Shadows in this game will either be very limited to a small radius around you but be very detailed or be very blocky but seen for miles. You will have to strike the balance for yourself.
Right, sorry to say I'm not reading through ALL these posts. I'm downloading the game via Steam (Thanks bro! Ace present!) so is there any mods or texture packs that are recommended before I start?
So is there any "must have" list anywhere?
I quite like the look of some of the replacement menu systems and also the Immersive Water v3.
There are a few horrid textures in places which are a bit shocking but apart from that, the game is gorgeous!![]()
Got Skyrim for Christmas, and so far I have no desire to mod it at all. With Oblivion I was modding everything in sight to get it the way I wanted. Skyrim though.....the occasional stupid texture or inventory niggle aside, it's amazing. Think I'm just going to forget about mods and enjoy the game!
You are missing out! You think it looks good now...? Well it can look much better!You are missing out! You think it looks good now...? Well it can look much better!
Ahhh the Silly Level of Detail mods are back. They had disappeared from the site...
Cool, I'll get them updated when I get home!
