Siri on 3GS? :O
Ok, just installed Spire from Cydia and rebooted ( ended up with the 1/4 screen issue once again but the previously posted method to fix that works ). Then started reading about Spire and what is required as far as setting it up goes. Didn't realise it is next to pointless ( despite the developer maintaining that it isn't - it certainly looks like it is at this particular point in time ) unless you have access and details of a proxy to allow access to Apples servers. Considering Spire sends everything you do with it to Apple via whatever dodgy proxy settings you input into your phone, I am thinking this could possibly be a bit risky.
I think I'm going to restore from a backup in iTunes and re-jailbreak. But this time I'm not going to use Aptbackup in Cydia as I would appear to have reinstalled almost everything I had to date, mod and Winterboard wise that slowed my iPhone 4 down to a crawl in the first place. This time, SBSettings will do, I'll not bother with Winterboard and even Lockinfo seems to slow everything down a fair bit, I'm thinking there's a sort of conflict of resources between it and the notification centre that comes with iOS 5.
What version of redsn0w are you using? What IPSW version are you using to tether-boot?right new issue. downloaded corona. all seemed well and dandy. however when i launch any app i have downloaded, including cydia, they just quit straight out. its like i have downloaded the semi tether as when i launch safari. it crashes out. my mail doesnt work. i still get signal and such and it tis rather annoying. im going to try and use redsn0w and ' just boot ' the device to see what happens. any one else shed any light on this ? i dont want to re jail break as ill lose my app data , more importantly game saves ;(
edit : right update. did just boot in redsnow and cydia is now working. going to try and download corona and see what happens
edit 2 : found corona. tried installing it and it said cant fix / find .. some file path. try manually fixing it. have no idea where it hides and any stuff like that. any one got any hints ?
Right, just finished off restoring from a backup and re-jailbreaking with redsn0w 0.9.10b3. This time I'm not going to use Aptbackup and clog my phone up with all the crud I downloaded from Cydia previously "just to see what it looked like".
Going to grab SbSettings and leave it at that for now.![]()
I get the feeling that out of everything I was running, Lockinfo was the resource hog. Not previous to iOS 5.0 ( seemed to run fine with no performance loss on 4.1 ) I have to say but as I said earlier Iam not 100% sure but Lockinfo seems to clash a bit with Notification Centre. I've now got Five icon dock and SBSettings installed and it seems fine. Might tweak a wee bit more but I'm staying away from Themes and anything that makes Winterboard work hard.![]()
i jailbroke my IP4 with the beta1 of redsnow (untethered) - do i need to update with corona?
No
Edit: You might want to re-jailbreak with redsn0w b3 though. Make sure you choose not to install Cydia though.
Thanks. does that mean i will lose everything i installed through cydia already?
