With onboard video?
yes, I'm running dual monitors using the onboard video without problems.
With onboard video?
Figured it out - its the displayport mate.
Works fine using a DVI cable - wierd problem, think I've heard it mentioned before about the Z68 chipset come to think of it now.
I'm glad you figured it out![]()
That is a nice chip, getting 1.32V with 4.8 is a complete no go for mine...
What setting are you using to get the Vcore?
Whoops that's what happens when you use auto white balancehow come your BIOS is blue? hmmmmm
Anyone which is the best bios to be using?
Thanks![]()
I am using 1.10
I got my new asrock z68 for crimboand I love it, But when I move my mouse I get a strange noise in my headphone's ? There is a problem in DEVICE MANAGER something about USB device not recognised ?
I have loaded all the drivers that come with the motherboard to do with USB but can't get rid of this issue in Device Manager.
If anyone has had this noise problem let me know thanks.
The noise could be down to Intel speedstep,try disabled and see if noise stops,changing your psu and or gpu to another brand might fix it,its electrical interference between psu or gpu and the mb/chip power saving states
