Diet wise, well porridge is a good start to the day, I like it, but tend not to have it really these days. I'd try and have a bigger lunch or at least a more calorific and a smaller meal before bed rich in EFAs and protein and less carbs. That's down to how my metabolism works howerver.
When you're sleeping it's when your body does it's growing/fixing. Eating is a very stressful process on the body believe it or not, it canes your body, and stress on the body releases cortisol which you want to keep to a minimum. since when you sleep your body metabolises it, you want to give it the maximum chance to fix you - so if you're stressing your body with trying to digest a lot of foods, especially high in carbs, you won't let your body recover as well as you should. It's another reason why I'm famished when I wake up!
However, this is just my basic understanding, of course everyone is different, and some people react differently to stimuli on their bodies. However, you have to give something a good few months to bed in to get a feel for it.
Cost is always an issue, and as much as I don't like supplements, if you really have no ability on getting more protein in you, then shakes are a viable alternative - however protein alone won't really give you the calorie fill or satiety unless you combine it with something a bit more filling.
Great info! I will make sure I take this and use it wisely. On the not eating so much or lighter meals, I burn food very quickly which means I don't gain size very easily meaning I need to get my body used to higher doses so I believe all my meals need to be bigger to get my body used to it. I didn't used to eat very well.
I feel like currently i'm sitting around 12-14% which seems to mean any changes in bodyfat are pretty much unnoticeable so it's hard to gauge progress.
Sounds like absolutely nothing..Out of interest...Is there a good resource for learning how this stuff works? As you seem to be quite 'with it' when it comes to how it all works.
Would be interesting to know and see if anything can be applied
Sorry... but that's basically what I do I read books about it. Which reminds me, I need to ensure I get them this weekend.Great info! I will make sure I take this and use it wisely. On the not eating so much or lighter meals, I burn food very quickly which means I don't gain size very easily meaning I need to get my body used to higher doses so I believe all my meals need to be bigger to get my body used to it. I didn't used to eat very well.
I can't remember if I was 12% or 14% BF, but either way you're a lot leaner than I am mate. I'd put you at circa 11% from what I can remember?
If you can, record (using dailyburn or my fitness pal or similar apps) what you're eating. Even down to tea and sugar, and chewing gum etc... literally everything.
Crap that's one thing that will suck about cutting. I never even counted any sauces, oils, drinks etc i consumed![]()
Skillmister just be careful you don't cut calories suddenly - taper down certainly if you were on around 3,500. Perhaps try and taper down to maintenance, though bear in mind you've probably added a lot of lean body tissue which in turn will enhance your metabolic capacity. So I reckon your MBR has possibly gone up - though you've taken that into consideration, do you know what your MBR was before?
blairw - your regime seems pretty good, certainly if you're as active as you say you are.
I think your diet is okay, but I don't know what your macros are - if you're hitting the right calories you'll be doing ok. Are you currently hitting a plateau or are you making steady progress. Doing it the way you're doing it you will get results, but slowly, but it's my preferred route to do things.
I'd ask about your intensity/voulme for your weight lifting - get that right added with the activities you do outside of the gym I think you'll be burning those calories. By getting the intensity/volume right in your training you'll help build develop muscle which in turn will help with the fat loss.
Well i've been eating around maintenace since i came home so it won't be much of a change.
No idea how my MBR has changed. I didn't care when bulking i just ate and ate![]()
Thanks Freefaller.
I weighed in at 16 stone 8lbs at the start of october, and this morning I was 15 stone 12lbs, but this is the result of the festive binge, at the start / mid december i was 15 stone 7lbs. I'd imagine I will be back down to this within 2 weeks as a lot of the weight gained will be water. So thats basicaly 14lbs in 2 months, but I was no where near as strick with diet, and I wasn't lifting regularly at all, only going in and bashing about the weights for a couple hours a week.
I will hopefully continue this plan, and stick around this way of eating until possibly mid febuary. I will definetly lose weight doing this, but I don't really want to lose it too quickly, so may up the kcals if it is flying off. Fitness levels from start of october now are night and day however, but i have been basically living on court since then.
It also depends on what you want, more muscular physique, or be leaner and fitter.Bear in mind as you build more muscle the cals will be used up more readily.It also depends on what you want, more muscular physique, or be leaner and fitter.
