Sorry phil, I might be skilled enough with soldering, but i'm not particularly hot on finding and repairing faults. Could be as simple as the IR receiver in the amp no longer working or the IR emitter in the remote not working.Kei can you fix my amp as remote sensor has just gone in my yamaha DSP-AX759SE 7.1 amp, or give me a clue how to fix it.
Hi there, really like your stand that you have for your TV. By any chance do you remember where you got it from? Also how long is it and how high is the shelf?
Thanks very much![]()
Hi,
It's the Ikea lack as someone found above! Not sure on dimensions but they should be on the link.
Just about managed to squeeze it into a Ford Fiesta but had to drive with head at an angle![]()
) Is that an XLS400 on some granite ? if it is, what is the grant sitting on?
Same speakers but got rid of the horrible wallpaper I had.
Beautiful. I'm betting that sub is thunderous!
