just got the update.
it's broken my game.
tried to activate a lever in a cave i was in to progress and it wouldnt work.
tried to do some other missions. i had to find someone but when i found them it didnt "update" my mission status. same with other quests.
so 40hours down the pan ?
Ps- tried another save firther back, no luck
No mods or ini tweaks?
none.
I don't really get what they're supposed to do either. All I can think of is they make the whole 'unlock' zone bigger by that percentage which would be nice for Master locks.
Major performance improvements with the new patch. Things are so smooth now in comparison to before for me.
- Verify integrity of the game files in Steam.
- Try copying all saves to another folder and leaving just one to load.
- Start a new game, save after the cutscenes and load that save to see if it works.
- Delete Skyrim.ini and SkyrimPrefs.ini from My Games/Skyrim.
- Disable MSI Afterburner if you use it.
Try them in that order, I'll get back to you if I can think of anything else.
2 files failed to verify. they are being aquired again. do you think this will fix it?
just downloading now
It should do if something was missing in the download or files became corrupted.
You can also try deleting Skyrim.ini and SkyrimPrefs.ini files from the My Games/Skyrim folder as the game will recreate them from scratch on launch.
They definitely make a big difference for meIs it me or are these rings and necklaces of lockpicking utterly useless? I've had no more success wearing 45% increased lockpicking apparel than without them.
That doesn't mean I haven't had success with master skill locks, just that the apparel doesn't seem to make it easier.
If you're experiencing crashes/freezing try uninstalling SKSE or Script Dragon if you're using them. I was using them with the beta patch (the most up to date versions) and was getting lots of crashes, but since I uninstalled them it's been very smooth. I'm guessing they need to do a bit more work to make them compatible with the new patch.
Script Dragon isn't compatible yet.
i hope this is soon sorted, as i liked my iHUD
