*** The 2012 Gym Rats Thread ***
Status
Not open for further replies.
I don't understand why it's so bad to do it? :p
If your arms are so big that you don't really care too much about them growing, then fair enough :)
There are plenty of exercises that hit the biceps really hard indirectly, I'd rather do that. Seems wasteful spending 20 minutes hitting a bicep when you can hit the back as well.
Do 4 x 10 hammer grip chin ups and your biceps will be destroyed, but if they're not then some rows will finish them off.
Well my arms didn't grow for ages doing standard back workouts + tricep stuff. Threw in an extra super set on triceps and some bicep isolation and saw gains very quickly.
Depends on your back workout I guess. Doing any type of chin up will totally wreck your biceps.
But LiE, everyone is different :) You might be lucky in that your biceps respond well to just being a secondary target in back exercises
But a lot of people, including me, need some extra isolation stuff to encourage growth :)
True, but have you tried doing slow all the way down to the bottom chin ups? To me this feels primarily like a bicep exercise and secondary back.
Monster biceps!
Doing 4 x 8 of hammer grip chin ups, very slow and strict has my biceps bursting. Strange.
Well, done my leg workout today, jumped the squat up for 5KG compared to last session as opposed to 2.5Kg...going to hurt tomorrow.
Will post the workout and a vid later x
Monster biceps!
Not saying it doesn't hurt, that would definitely be hurting by the end. But I doubt I'd see any growth from just doing that
Reverse grip bar curls, hammer curls, wrist curls
And arm isolation work is important. Yes you'll work them a lot with back work, but you don't have to work them on the same day. For example, if you did Chest/Biceps on Tuesday, then Back on Friday, nothing wrong with that.
The thing not to do is a crazy amount of sets, do about 10 sets, 12 max on bicep isolation stuff. And leave your ego at the door, do weights that you can concentrate on form with. Too heavy and you're going to swing, or bring your shoulders into it.
If you do biceps on a day separate to back, go for something like this:
Incline Curls 3x12
Hammer Curls 3x8
Preacher Curls 4x10
If you do them after back, just go for something like
Lying Hammer Curls 4x8
EZ Bar Curls 3x12
21's One Set
Always leave my ego at the door anyway, the amount of friends I go with that swing their back or use their legs doing bicep work makes me cringe. Then they look at me in pity because I can't lift as much as them.
Erm maybe because your lifting with your back?? But then don't do deadlifts because they've heard some horror stories...madness.
Thanks for the advice will have a look at doing them next time I do back, as per the arguement I rarely ever do Bi's and they just never grow and I do pullups on every back day if not more.
Just gave overhand grip, instead of mixed grip, on deadlifts and its such a huge difference! I've never struggled with grip before, but I certainly did just now!! Also managed 110kg, 1RM though I reckon I could've pushed it up to 120kg :D
Double over hand is tasty for grip. I use alternating grip for normal deadlift work, because my double over hand isn't there yet. On leg days I do RDL with DOH grip and I'm holding onto the bar with my fingertips by the 10th rep!
Ta for the input.
Reason i'm keeping things linear is because every time in the past (since 2009) i've just 'gone for it' ive injured myself, and in all honesty i'd rather take it slowly and gain over time, after all ii'm in this for the long run hopefully.
At the end of the day, i'm making gains, poundages are going up. Yes, it probably could be done a better way no doubt, but it'd working for me currently.
Yes, i'm anal about form, but i'm not posting vids up every week? I just posted one from last weeks DL session just to see how things are getting on. As has been said, i'm going to up the DL weights by 5KG each session, not sure I want to do that on squats just yet for obvious reasons, because I'm starting to hit max for reps now as it is...That coupled with a lack of decent catchers I don't want to get stuck under the bar again.
Thanks again though dude, I appreciate the replys
I can definitely understand the caution if you've been having injuries.
As for deadlifts, yeah, definitely try to go up 5kg a session, that's pretty easy with deadlifts. I don't think I've ever used the 1.25kg plates on deadlifts except for on 1RMs.
Squats, you can definitely get away with a couple of sessions with 5kg increases, but I wouldn't do too many. A handful at most, then just stick with 2.5kg increases for squats.
First time I've done them as mixed gripped always felt natural, definitely need to do some more DOH. My grip gave up on 100kg before my strength did, so think I will stick to DOH from now on till my grip builds itself up a bit as its weak as ****.
And any other noobs out there, I found this article to be a very good read and took it on board to do. Felt much better today.
http://www.t-nation.com/free_online...ou_ignorant_when_it_comes_to_the_deadlift&cr=
Status
