- 23 Mar 2011
Is uncharted a straight port of the latest ps3 version or is it completely different levels etc.
totally different game/story! set before uncharted 1
When you setup the vita with the memory card, how much space is free?
Interesting to read the user reviews coming in. Any word on a GT release?
Back touchpad not working in FIFA demo, is there another way to test this? Better not be broke ><
I just thought mine was bricked, no apps would work then the screen just went black with a spinning icon for ages and wouldn't even turn off.
I found a diagnostic menu of sorts though (just hold the power button down for 15 seconds) and reset it, it's fine now.
That scare aside, it's brilliant. It really is a great machine.
This is prob going to sound the most stupid question ever... I turned my Vita off and put it on charge, I've taken it off charge and can't turn it back on. The blue playstation light keeps flashing and I've pressed power and the blue PS Vita button but nothing is turning it on![]()
near working for u guys? cant find my location
Ahhh, that explains why there's no Elena, I did wonder.
Hold the power button down for about 20 seconds. if it still does nothing then plug the power back in and try again. If still not working wait 30 minutes and try again.
Yep, got about 9 people within 9KM of me. It didn't want to connect 5 or 6 hours ago though. No idea why.
Are you using 3G or are you on a WiFi unit?
Hi Philip,
Unfortunately your order was shipped before we could process the cancellation completely. Unfortunately the refund went through, however.
Instead of sending the product back, would you be interested in a $10 discount to keep the item?
Kind regards,
Rune
PlanetAxel Customer Service
[ZiiP]carrot;21324150 said:Cancelled my 32gb stick order last night, only to get the following email this afternoon:
The card came to £70 after charges and whatnot, and being offered around £6 back to keep it....but can't really justify spending that much on a card atm.....
wifi unit buddy
Try doing it on the Vita with the WiFi off, just using the network. Once you've done it for a bit, and if it's too slow then put WiFi back on. Also, if you're using a VISA card change it to VISA Electron on the drop down box. This exact process worked for me![]()
Just looked at some of the games which will be coming out and all I can say is I cant wait !!!!
LEGO Batman 2: DC Super Heroes
Assassin's Creed
Bioshock
Killzone
Resistance: Burning Skies
Cheers mate, that did the trick
Left card on Visa and just turned off wifi, just waiting for my code now.
How long does the code take?
