Looks like a good build. I love how you used your budget very wisely.Reminds me of myself
EDIT:
What camera did you use to click the pictures? I love the shots![]()
Silencer is available from the gun shop in the chinese brothel in Shanghai (and also from a shop in a flat in detroit- if you save the woman hostage on first level, her husband will tell where it is and how to get a discount![]()
Glad its working and your enjoying it![]()
Yeah, I remember seeing it. I'll try to go back and get it. I'm in the TYM building at the moment.![]()
Dont skimp on side quests - some are really awesome.
Oh, and congratulations on the card again- I take it all settings at max run with no problems?
Yeah, this Antec 300 is so crap. I now remembered I'm also going to have to remove the motherboard to put the cpu cooler on. -_-
Ah dammit, nobody warned me not to get the upgrade chip. Now Namir is stomping me.![]()
I think I had a lot of grenades and mines, so I would stand next to a corner and as soon as he would start running towards me I would start chucking all this explosive stuff in his direction. Mines are best because they detonate right under him. It took me about 20 goes though, maybe even more
I got it used for £30. The newer ones do have a cutout, the old ones doesn't. This is something I overlooked back when I bought the case.
Yes, £30(including shipping) is not to bad considering you got 5 fans there as well.
I had one fan in my case and and bought one silent Xsilence Red Wing fan which was about £4. I have only 2 fans in my case at the moment, but heat is not a problem- I have overclocked both CPU and GPU (manually, auto OC is hotter) and both run under 70C on full load.
I've read that Antec fans tend to be louder than most, but yours must have their hydro bearing worn out. A lot of fans use those bearings nowadays because of they are relatively quiet, but the downside is they wear out quicker. Also LED fans tend to be noisier than non LED for all makes it seems.
I am also running one fan on bottom front and one on upper back of the case and it seems to be enough.
I've also cut out fine mesh pieces to cover all the vents in the case and this seems to eb working very nicely- no dust at all in my case after 2 months![]()
http://uk.ign.com/wikis/deus-ex-human-revolution/Side_Quests
