The Touchpad Android thread
my all 120 apps where installed automatically, now first couple questions: Camera doesn't work? and when I connect device to PC my computer won't install usb drive.
Nope, no camera yet
Any suggestions for good games to play on Android please folks?:)
Also - anyone got the bluetooth PS3 Sixaxis working yet on ICS?
Six axis works fine on cm9, it has done for a long time.
whooaaaaaa, I only just saw yesterday that things have updated since Alpha 0.6, I'll update to Alpha 2 and try it. If that works this will be the ultimate tablet for me, iPad Slayer!
thanks for the games tips, i'll surely try some!
I just installed cm9 alpha 2, it connects to my router but the browser cant get to any web sites, anyone else have this issue ?
Grand Theft Auto is good.
cheers for the tips guys. Has anyone tried N64oid? I booted Banjo on it last night and it looked amazing, really hoping to get the PS3 pad working with it for a bit of travel I have this week.
The problem I seem to face with my PS3 pad is that when I press the PS button nothing happens unless it's just been connected to a computer via USB.
Question: Does CM9 A2 cripple the wifi speed if the battery is low? I also have the Modpack installed from Rootzwiki if that matters....
My touchpad has stopped charging via the Touchstone. Any idea how I can work out if the Touchpad or the Touchstone is the issue?
I have booted into WebOS and it still won't charge.
There can be charging problems due to low battery when using CM7/9.
Have you fully charged it using a cable and then tested charging with the touchstone?
Also booting into webOS might not be enough you might need to hold both buttons for 30 seconds to do a full reset. Sometimes I get WiFi problems when switching between ICS and webOS and doing the full reset fixes it.
Does anyone else have problems with poweramp gestures (up/down) to change album not working? also seems to be stuck on shuffle!
If i re-install it then it is ok for a bit but soon goes back to having problems!!
I'm on cherrykany 0.9.2
