- 22 Apr 2011
- Nottingham
Long thread is long, When we seeing gk104? (roughly)
This is a prediciment for a few I bet. The longer you wait the cheaper the 580 will get IMO but that doesn't help you if you want the new Kepler, when the specs are finally released.
If this is indeed the midrange part, and everything points to it being so, there is no guarantee it will be a decent upgrade from a 580
It WILL be the GTX680 according to Fud...
So my new improved list about the GK104:
1.)Semi-skimmed GTX670TI was 5% slower than HD7970
2.)Magic BIOS flash gives 40% faster speed than HD7970 for GTX670TI
3.)GTX680 was 10% faster than HD7970
4.)Speed of GTX680 with Magic BIOS unknown
5.)3DMark11 score 15% higher than HD7970
4,)Semi-skimmed GK104 has 3DMark11 score 5% lower than HD7970
5.)Consumes less power than an HD7970 and is a 195W card
6.)Has a smaller die
7.)Has 2GB or 4GB of VRAM
8.)Can use system RAM
9.)Shorter PCB than a GTX570
10.)Is only $299
11.)Has backlit GEFORCE GTX logo on the top of the card
12.)Is the PhysX MASTER
13.)Has single card surround
14.)Is the UE4 MASTER
15.)Has the same memory bandwidth as the GTX580
16.)Does some other stuff that I might go WTF at
17.)Uses a Vapor chamber
18.)Uses an HT like technology
19.)Uses a Turbo Boost like technology
20.)There is no GTX670 but only a GTX680 as the former was a smokescreen
21.)Most of the rumours are not true at all
22.)The card launches today
23.)Availability will be poor at launch
That is all the rumours I can find ATM.
Of course, other side of the story comes from Nvidia's "disappointment" with AMD's Tahiti GPU and Radeon HD 7900 series that was detailed back in January and it might be the point in time when Nvidia decided that GK104 could be launched as the GTX 680.
So I was right, then.
http://www.fudzilla.com/home/item/26289-nvidias-upcoming-card-is-gtx-680
IDC if they call it the GTXpileofpoo. All I want to see now is game benchmarks.
You will care when you see the price after we all expected GK104 cards to be <£300.![]()
Yeah that's how I figured it went as well...
So basically all the Quadro and Tesla cards are going to be GF110 based for the foreseeable future or are GF104 cards meant to be replace them?? I would think the major point of developing the GK110 would be for commercial and professional uses,where Nvidia makes most of its money from.
