- 30 Nov 2011
pretty much, forums got an ignore function for a reason though
please for the love of god where, I can't find the ignore button
Guys, ALX Andy is clearly a troll of the highest order
he keeps posting deliberately inflammatory and contradictory arguments and even posts links saying graphics card x was 150 and y was 450 but the same when the links show one was 19FPS and the other 100fps in the same game
he is deliberately misquoting, misconstruing and misrepresenting everything he says
as far as trolls go, 66 pages is a good "score"
What about when he has a go at AMD then?? Is he an Nvidia troll too??
I assume you missed all his posts on that conveniently?? An example is this thread:
http://forums.overclockers.co.uk/showthread.php?t=18383174
He has a go at BOTH companies.
Is the 680 a stopgap before we see a 7xx named card relatively soon?
I'm a Matrox M-Series fanboi.
So my new improved rumour list about the GK104:
1.)There is no GTX670TI but only a GTX680 as the GTX670TI was a smokescreen
2.)The GK104 was not called a GTX680 but Nvidia decided to do so now
7.)The GPU can be overclocked by 40% on air. Is the overclocking MASTER and clockspeed MASTER
13.)Can use system RAM
14.)Shorter PCB than a GTX570
15.)Was $299 but now $499 or $599 since Nvidia was disappointed with AMD
16.)Has backlit GEFORCE GTX logo on the top of the card
17.)Is the PhysX MASTER
18.)Has single card surround
19.)Is the UE4 MASTER
22.)Does some other stuff that I might go WTF at
24.)Uses an HT like technology
26.)Most of the rumours are not true at all
27.)The card launches on the 22nd of March
28.)The card launches on the 23rd of March
29.)Availability will be poor at launch
30.)Availability will be great at launch
3.)Initial cards did not have the magic bios,but after the magic bios were converted to GTX680 cards
5.)As fast as an HD7970
6.)Is 25% faster than an HD7970
8.)Consumes less power than an HD7970 and is the performance per watt MASTER
9.)Has lower TDP than an HD7970. Meant to be a 195W card
10.)3DMark11 score 15% higher than HD7970
11.)Has a smaller die of under 300MM2 compared to the 365MM2 die of the HD7970 and less transistors. It is the performance per MM2 MASTER and performance per transistor MASTER
12.)Has 2GB or 4GB of VRAM
20.)Has the same memory bandwidth as the GTX580. However,it is very efficient at using memory bandwidth and is the efficient memory bandwidth utilisation MASTER.
23.)Uses a Vapor chamber
25.)Uses a Turbo Boost like technology
I'm just calling a spade a spade. I do that with everything. Want to know how great my 7970 is? Well, not only have I wanted to cut it in half and smash it with a hammer this week but I have also made my thoughts clear on how bad I think the drivers are.
I assume you missed all his posts on that conveniently?? It seems rather selective reading if you ask me.
What problems have you had with the drivers for your 7970?
this is only an example of how he massively contradicts himself just to get a rise out of someone, I'm not saying he's a troll or fanboi to either company, just either massively self conflicted or else deliberately trying to get a rise out of someone
if someone posts in favour of nvidia he calls them an nvidiot and then if someone posts up that gtx680 will be too expensive he lays in to AMD
he's not being particularly pro either company, just massively whiny and argumentative
Most of the problems for people seem to come from using 2 or more 7970's. As of yet I've had no problems at all.
