So NVIDIA doesn't currently have a high end product and wont until next year.
Ridiculous...
690 out in May.
Ridiculous...
Wouldn't it make more sense to get a GK110 when it is released at the end of the year??
690 out in May.
...and all of this is happening because AMD stacked their new gen cards pricing on top of/along side with last gen cards (basically charging last year performance at last year's price). This wouldn't have happened if they priced the 7950 and 7970 at the same launch price as 6950 and 6970 (might be just a little bit higher). £100 higher is simply too much.So NVIDIA doesn't currently have a high end product and wont until next year.
Ridiculous...
690 out in May.
It will be a lot more than £420, I have a rule never to buy a graphics card that costs more than £300, the GTX680 is an exception as its better than a 7970 but cheaper... can't argue with that.
I doubt it TBH. I see the GTX780 coming out and the GTX680 being rebranded as a GTX760 or GTX770 with a lower price tag.
There is another thing though, the GTX580 has dropped down to around £300 now too and the standard price might possibly drop even further.
Even OcUK have a GTX580 for around £288 on special offer:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-146-OK&groupid=701&catid=1914&subcat=1812
I honestly don't see that happening. If nVidia are holding out and releasing a better card down the line, how will AMD respond.. they don't have a card higher than the 7970 (7990 is dual GPU).
When nVidias better cards come out end of the year, AMD will respond with super OC versions of their 7970 with possibly more VRAM. Even then both these nVidia and ATI cards will be out of my price range.
£100-£150 higher the its predecessor!Higher than what, your expectations?
The way I see it is 7970 nad GTX680 are their best offerings. In a few months time nVidia will be launching a competitior to the 7950. Then end of the year their launching a card better than the GTX680 meanwhile AMD have a chip in the pipeline that's better than the 7970.
Is the about right? If so the GTX680 at £420 is a no brainer as it won't be reduced by much in price by the end of this year. Its safe to say AMD's rumoured card and the >GTX680 card will both be around £500+ which is out of my budget.
I was very close to getting the Sapphire OC 7950 for £380, but of the GTX680 is only £40 more it doesn't make sense.
Are you that bad at reading? I clearly said the 7950 and 7970 are £100-£150 higher in price than the 6950 and 6970!Which was their last gen fastest single GPU card (a 580) or based on your expectations a 560?
