*** The 2012 Gym Rats Thread ***
Status
Not open for further replies.
Aiye, going to start working on the chin. No idea why I point my feet out like a squat - will keep them parallel for next sxesh.
There is definitely something in this "no trainers" squatting!! haha
Tried it today and found it much more stable and dare I say a bit easier than the last set I did in socked feet.
Anyway - short of time today so no cardio but will try and get out for a run later.
warmup on treadmill
3 x 5 reps @ 50kg squat
3 x 5 reps @ 35kg bench press
3 x 5 reps @ 45kg bendover row - last set was a struggle.
Some core stretches and workout
Looking good monkee. Try and be more explosive, you're glutes are mighty strong and should be powering that weight to lock out.
Nice one Monkee :)
As LiE said, get those glutes in to action more, hump the bar if you have to at the top!
Probably nothing to note, but at 25s~ you heels pop up a touch (read: Hardly at all :)), so don't know if you leaned forward a tad or not...
Good work though chap! Especially over 100KG
LiE, I was trying believe it or not. I think this is actually pretty close to what I can handle. I'm virtually shagging the bar at 60 - 80kg, get it up past 100kg and everything slows down :D
I wasn't expecting to find out that LiE has inside knowledge of Monkee's glute strength.
We're a close bunch.......
Anyone suggest any good shoulder stability stuff? I've already got thing like single arm dumbbell bench and pressup(ish), med ball press ups, half kneeling single arm DB press . . .
Any more :)?
I've just purchased a unit where you can do pull-ups, dips, hanging leg raises and press ups, i only need it for pull-ups as there is nothing in my double garage where i can do pull-ups.
Going to be controversial here and say purely from a weight lifting perspective, stretching is a pointless waste of time
And by that, I mean stretching in the way that people normally think of when you say stretching, "warming up". Just grab some 1kg/2kg dumbbells and do some real high rep warm up sets instead
The only stretching that should be done is the type you would do in between sets of certain exercises. Or maybe some light stretching after the workout. But people that do 10 minutes stretching before a workout just annoy me immensely.
Status
