What happens if you run out of VRAM cause i think thats what maybe causing my bad textures?
Stutttttter![]()
You know that realistic ligting mod, where you have to enable it in nexus then run a separate patcher doodahh outside of nexus, if you want to back to default lighting, do you have to do anything to "undo" the patcher, or is it a case of just deactivating the mod in nexus?
It's mods to blame most of the time.
You guys might want to check this link out:
http://forums.overclockers.co.uk/showpost.php?p=21391938&postcount=1712
Then something is up because most people aren't getting constant crashes.Mines vanilla.
Thanks for that its an excellent post!
Started using Dynavision and Imaginator. Two clicks of the "Cool Midnight" preset in Imaginator.
Armour is the Black Sacrament Armor.
Only SkyUI is essential to game play on PC. Everything else either fixes some minor bug or adds some new texture maps.Would anyone be so kind as to let me know what the essential mods are to apply that will give a decent improvement in graphic quality, while not dragging down fps. Any other advice on "essential" mods would be appreciated.
