- 30 May 2007
- Glasgow, Scotland
I thought it was pretty much always recoverable...!
Doesn't go past the splash screen, holding the three safety buttons (power, home, vol up/down) only hangs the phone too and freezes up...
Kaput!![]()
I had the same problem Cyclone, it was fixed by using one of the cf-root kernels.
hey guys,
Im retiring the trusty GSII because i got myself a ONE-X im rooted with a stock ICS isntall. Im sending the phone in to a recycle site, Whats the best method to return to stock? I got a USB jig as well
Leave GPS running using GPS Test with the screen timeout setting disabled in the app. Leave it for 20~ minutes if need be. The GPS configs train over time for the first time you run a GPS app.
Also, use this: http://forum.xda-developers.com/showthread.php?t=1447599
This needs to be done once for the first time every time you flash a new ROM or update ROMs and after this point GPS lock will happen within seconds regardless of if you're inside or outside a building.
hey guys,
Going by install method 3 i just need to flash the zip in CWM, right? I dont know what 'no ssl' bit means so should i just download agps.patch.google.build.v3.1.zip?
Thanks
here's my battery life on sensation 3.2 - LPS modem - this includes gaming/texts/loads of browsing/camera/youtube/wifi etc..
for anyone that ones to try this rombattery life is good in my eyes
