Oh! Thanks, I will just have to be more patient.
I thought it was from the 12th April.
Based on the information provided, Sky Broadband Unlimited Fibre is not currently available, so we have been unable to add it to your basket.
Whats a better alternative to the BT HH3 for better speed and range? budget is £170
Most seem to have been given the 13th but some have later dates.
Your exchange is ADSL enabled, and our initial test on your line indicates that your line should be able to have an ADSL broadband service that provides a fixed line speed up to 2Mbps.
Our test also indicates that your line currently supports an estimated ADSL Max broadband line speed of 7Mbps; typically the line speed would range between 6Mbps and 8Mbps.
Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 15Mbps; typically the line speed would range between 8.5Mbps and 19Mbps. Our test also indicates that your line could support an estimated ADSL 2+ Annex-M broadband upstream line speed of 1.5Mbps and downstream line speed of 15Mbps; typically the downstream speed would range between 8.5Mbps and 19Mbps.
I'm moving into a place in July and, according to SamKnows, the FTTC upgrade should be completed by the end of June in the area so I'm hoping to jump straight in with Sky.
Apparently the place is approx 486m away from the exchange. Is this an adequate sort of distance to expect a good connection speed?
Exchange distance is irrelevant (unless it's TOO close, in which case you can't get FTTC at all anyway!). What you need to know is how far away the cabinet is.
So if your say 300 metres way from the cabinet , what sort of speed would you get roughly ?![]()
