Tribes Ascend
Status
Not open for further replies.
Cant wait to play later gonna try n see what perks are good with raider n unlock some infill goodies! Dont know about smoke bombs tho?
Raider is a tricky one, lot's of good perks.
- Potential Energy: works well with shield, transfers AOE damage to energy this prolongs your shield in certain situations.
- Survivalist: 20% heal from enemy canisters, good for generator attacking.
- Safety Third: Extra Grenade.
- Looter: Extra Grenade from enemy canisters.
- Ultra Capacitor: Gives you an extra 10 energy, slightly bigger shield.
- Quick Draw: 30% faster weapon switching.
So yea, take your pick. :D
Cheers for that hr 1.30min to go! Bloody work
shall have to update friends list
In Game Name = Excess
Is there anything that can be done to increase performance?
I have a system which I think should run this game on high - quad core, 4gb ram, 6870 etc but I have to play on MEDIUM to get a decent fps.
I know its UT3 engine, and I can play the game UT3 fine at maximum settings. I realize thats a old game now but TA doesn't look that much more advanced graphically.
Is there something I'm missing, also I played during the early beta stages and I'm sure I had better performance then and I think I was playing on high mode...and the game looked better then I'm sure.
Any help guys?
You *should* manage better than medium on that spec.
As SAmSuNG said, what do you consider decent fps?
The game has some optimisation issues with AMD systems, I think. The system in my signature gets 40fps on Ultra, which isn't great.
Precisely what processor do you have? The game is heavily CPU dependant.
Anyone know how to add Steam overlay functionality please?
From what I can gather, it worked in the Beta but since then, it does not work. I installed for the first time today.
I create a shortcut to the hirezlauncher with the game=200 product=10 switch. The launcher opens but then as soon you launch the game from the launcher, Steam does not realise you are in a game which I assume is because you are now running the Tribesascend .exe which you cannot shortcut to because of the stupid launcher.
HELP please.
Thank you.
HELP please.
Thank you.
I created a shortcut on my desktop and added that to steam, worked fine for a long while and allowed the steam overlay. But now any game i add to steam that isnt a steam game gets removed from my list on a restart so i just use a normal shortcut.
Status
