- 17 Oct 2010
Thought i would give an update since my last post...
Main thing first - still not had a real cigarette since the kit arrived.
Overall impression of the tornado tank - 2 months in
Build quality, still very happy, dropped it so many times at work and no breakages so far, plastic 'tanks' themselves still all working no problem, they do not seem to be wearing out, changed to squirting fluid through the hole now rather than removing the cap since getting different fluid bottles with smaller ends.
Main area in need of improvement from the standard tornado kit / parts is the atomizer 100%, everything else is fine.
Experiences so far trying to solve the atomizer problems
So far i have tried:
1) Standard atomizers from TW that came with the kit x2 (still working, but not so well) & 2 more from a local shop (local ones died really fast, under 1 week each
2) Cartomizers, both mega duals and triple coil versions, personally didn't get on very well with these, dual not working at all for me, no vape at all it seems, triple is working but not as good as the regular atomizers although more flavour, less vape (pretty much given up on these for the moment).
3) Low resistance TW atomizers x2 - big improvement, more vape, same level of flavour, they also seem to stay clean better, i found they didn't clog up anywhere near as much, vaped good until the end, but died rather quickly (approx 2 weeks each).
4) E-go low resistance atomizers - in progress not had them long yet - so far seem the best and only £4 a throw
Cleaning my atomizers by blowing through them gently and cleaning away the excess liquid, atleast once a day or more often if i feel it clogging up at all.
I would say blow gently, as 2 of the atomizers that have died on me so far did so just after blowing through them, they were working but clogged, then didn't work after blowing when it came to priming them afterwards.
My conclusion from this is to buy the e-go atomizers or just get the e-go kit from the start. IMO better performance and better running costs.
Part 2 inbound.. 5 mins
