obviously lowers the score for the same clocks.Score is fine bro, the others posted on this page are at 1680*1050, your's is 1080obviously lowers the score for the same clocks.
from all the posts in this thread i gather the 7850 runs incredibly cool even if overclocked at what seems to be running well for a lot of people at 1200@5800. My question concerns when do you expect to hurt the card. I would guess as long as it is not running aboth 90c 24/7 nothing can happen right? Can you acutally hurt the card when raising the voltage and overclocking without experiencing dramatic heat increases? Put another way, is only heat damaging a graphicscard or can it go bad at high voltage without heat issues?
I knnow it's been discussed already but in my case, to go from 1100 core to 1200 core requires 0.06 volt increase, and even though that still only takes it to a very 'safe' 1.155, is it worth it keeping it 24/7?
HeX did already mention that 1200 is very worth it for BF3, which I play, but I was after opinions on if the extra 100 for .06 volts is worth it?
These cards are designed to run at around 80c-90c max temps as "Hex" says. Its the impression that ppl have that lower temps means better overclocks and longer life. To some degree this true, but even if you lower the temps by a lot, (since I installed a Gelid twin fan cooler on my 7850, I never see temps over 45c in ANY application, but my overclocks remain the same). The main problem is overvolting too much and atm theres no definitive max safe voltage for these cards yet, only time will tell, but going by what other ati cards are overvolting to and their owners having had their cards at these values, 5850/5870, etc you can extrapolate (great word that) that 1.2v is a generally acceptable setting for 24/7 useage.
Also bear in mid this voltage will only be applied when gaming and benching, etc, as when idling in desktop, etc, its only gonna be using a lot lower voltage, somewhere around 0.9 volts I think.
Thank you guys, i was lucky enought to find this forum, and it was clear for me I had to buy this card for my first new pc desktop.
Here its my contribution. From a newbie.
Sapphire 7850 non-oc edition
Cheers form Portugal
