Great, now at least theres a baseline voltage increase ppl here can go by, thanks for posting.assuming they're refering to reference cards where the voltage is supposed to be the same across all brands.
that was in regards to the sapphire OC edition, so i'm not sure if it is the same for other cards, but likely so.
So I'm guessing anything below 1.25v be it Sapphire, MSI or Asus cards will be safe right?Anyway, I believe most people OC only when they're gaming? Since OCing when idle is redundant.
your card downclocks at idle just like your cpu, so you can leave the overclocks active 24/7 or not. either way they will run at the exact same speed and voltage at idle.
just to note, sapphire tech may have suggested 1.25v, but degradation still exists even under safe voltages. my e6750 cpu was OC'd at safe voltages for 2 years, then suddenly would not hold that OC no matter the voltage after those 2 years. so just keep in mind you can run 1.25v nonstop if you want (according to sapphire), but that certainly doesn't mean your card will last indefinitely at those voltages. remember, the GPU core is only one temperature you have to be concerned with. the voltage modules also get hotter the more juice you give them.
