Been using my new One X last night (Wifi Only at the moment)..
I'm very impressed, I'm fully up to speed on XDA with all the issues, and amazingly this one has none!
- No loosely fitted screen
- No yellow spots
- No dead pixels
- No flickering greys
- Wifi Seemed to stay connected after 3 hours of screen off
- GPS locks within 5 seconds if I'm within sniffing distance of a window
- Came with 1.28 on it
I did find the slip case the seller gave me (original HTC alledgedly) was a bit loose, but I luckiily found a nice transparent gel case on eBay that arrived at the same time, it looks unobtrusive, protects the front screen/camera when lying on the desk and also makes the slip case fit much more snuggly (and not too tight)..
I know the S3 is quicker and possibly slightly ahead in some other ways, but I'm amazed at how performant and nice to hold/use this one is...
I might try Apex later on, with Beautiful or Fancy Widgets I can probably do without the Sense stuff, although I've already found that turning off the "Show touches" under developer options has smoothed things up a bit, that animation seemed to cause some stuttering when you lift your finger and the animation decays..
- No yellow spots
- No dead pixels
