A higher power limit BIOS would be good!
The 670's aren't going anywhere near their Max power limit anyway even when overclocked, so this won't help. What is needed is full core voltage control.
Is there any reason why Nvidia have locked down the voltage liek this?
I understand it is good for power saving. But they know people are going to be overclocking as its a high performance card. Why couldn't they have made it so you could unlock it yourself?
Perhaps they know with an unlocked voltage, under water these cards could do 1450-1500mhz. Maybe more.
The OC KFA2 and the Windforce are comparible performance wise?
Overclocked 7970s run far hotter and make much more noise than GTX 670 / 680 do. I cant even stand my KFA2 card on max fan speed and its really not too loud, I couldnt deal with anything louder.
guru3d said:We applied a hint more at 1300Mv and ended at 1250 MHz with a stable overclock, and that is very nice. The GPU was hardly getting warmer as we reached 70 Degrees C but by compensating the additional heat, the cooler RPM went up and as such the noise level now has risen towards roughly 41~42 DBa, still extremely respectable.
I got a Gainward GTX670 this morning and the fan is annoyingly noisy even when not under load.
Seems like these stock fans on the 670's are really not that good.
** quote removed **
same temp as a reference 7970 and 2DB louder... direct CUII 7970 and windforce 7970 both tested as 3DB quieter than stock 7970, so in fact quieter than your card...
You really have a penchant for talking complete and utter cr*p don't you!
Its not the fans that arent good, they are the same as the 680's.
Its the miniature heat sink that you wouldn't even find on a £80 card let alone a £300 one. Which means the fans have to spin faster.
Likewise you dont own a GTX 670, yet state all your opinions about how you think the rubbish reference version is a godsend and better than the custome versions.
You make no sense, according to that review the 7970 at stock frequencies is louder than my card.
I dont own a 7970, I have read from several people on Xtreme Systems who own one that it is very noisy when overclocked.
More like AMD users like to hide the fact that their 7970s clocked to 1200 Mhz sound like hairdryers.
