- 11 Dec 2005
- Cheshire
got my FRSU next week at ABP
tempted to chuck the JDM ARB on at the same time.
with your lowering springs too yeah
with your lowering springs too yeah![]()
Anyone used a machine polisher before?
Tempted to buy one and have a bash at getting rid of some scratches and swirl marks![]()
Thats on all of those platforms though![]()
Yes. The first thing I did was get the DA on my NHB! (Pic few pages back)
Took so long to get where I was happy but it was badly swirled up!
I used 3m Perfect it 3 range, Meguires SwirlX and a variety of different pads.
The final outcome was spot on although it took me almost 3 hours initially to find the right pad/polish setup. Found the Swirlx did the trick on a light cut pad followed by the 3m final finish polish then finished with 3m Marine wax.
The end result was fantastic. A deep black glossy finish.
Overtime about 1 year since I first detailed theres some slight swirling appearing (rushed weekly washes) so i've ordered some new kit and will be trying Poor Boys Black Hole and Meguires ultimate quick wax.![]()
Im in the same boat as you! Nhb Ctr! Its only now the sun has come out to play that ive noticed how bad they are!
Where did you buy all the stuff from?
1.7 litres rings a bell to fill the box.
Use the standard Honda MTF oil as well.![]()
they say it comes in threes so thats 2 things in a week after ages of not a blip from it,think its spat its dummy out cos ive not washed it for a monthIf you already have one then get it on, they are easy to fit.
