Manual brightness, I don't use Auto and plus I find it too dim on auto on the S3 with stock kernel.
Web and games total time is hard to tell exactly but guestimate would be a couple of hours combined. The rest was all using various aspects of the phone as mentioned. Oh and 18 minutes of voice calls.
Haptic feedback was left enabled of course and keyboard vibration. I've now turned off the capacitive button lights as I don't really need them on, looks smarter too
Yes and No. For text the OneX screen is a bit nicer to read on but only at lower brightness levels/ higher than 50% and it's too bright but so is the AMOLED for indoors usage. outdoors the GS3 is fine, easier to read than the S2 from what I can see.
Can you guys with cameras that have manual control test something for me?
Following on from a post by someone else about weird blotches on an all black image displayed on the screen, I checked mine today in pitch darkness and noticed a faint 2 inch or so of blackness on one edge of the screen along with smaller blotches. It doesn't appear to be as visible as the other poster's though but I exaggerated in in the photo so it's easier to see and settings posted below for people to check as well.
This is only visible on an all black screen. This does not exist on any of the S2's I've owned. I'll check my dad's S3 tonight when I go see him in the same way but the way to photograph it to keep the results consistent are as follows:
Stick camera and phone in a cupboard and...
Phone screen brightness: 50%
Camera ISO: 200
Camera Shutter: 15 seconds
Camera Aperture: f/4.5
Remember to pre-focus and use the 10sec timer to avoid shake
Those settings will over exaggerate the effect as shown in my photo below but it makes it easier for everyone to see as you do have to focus your eyes in reality and it's not immediately obvious unless you're in pitch darkness and looking at an all black screen.
I don't know how I feel about this though but if it's visible using the above camera settings for lots of people then I'll leave it as is.
Again, it's only visible on an all black screen so make sure your image that you load is all black and not grey or something
Make sure screen timeout is set to at least a minute to avoid the screen going off!
So far this many people h ave reported similar blotches:
XDA: TBC
OcUK: 1
