*** The official HTC One X thread ***
I may be mistaken, but I think HTC have done this (and it will be part of the next OTA update):
Daft question probably but If I was to buy a simlocked T Mobile Handset and flash it with an Orange UK RUU would it make the handset Orange simlock?
Phone is being collected tomorrow by HTC to be repaired. Screen has a stuck pixel and a yellow area. Also it keeps saying emergency calls only when my other htc on the same network has full signal.
Took my One X back to CPW for a replacement. They reckon my stuck pixel was dust under the screen. Makes sense seeing as it appeared bright white under sun light but disappeared inside.
Either way, I got a replacement.
Selling my One X as I just picked up a new Samsung pebble blue SGS3 earlier today...will be sad to see it go but tbh I prefer the SGS3 over the One X especially software wise as it seems to be optimised.
Flashed ARHD 7 and I can indeed confirm that the change Robbo mentioned is present in the 2.0 Sense update.
Yeah, that's where I saw it! Wasn't sure if it was official but it looked it.
I'm trying ArHD7 + Franco kernel at the moment, will see how it goes.
Ah, cool. I think I read somewhere that the 2.0 sense update would have the function but I wasn't sure.
I'm thinking of flashing Franco kernel again but the last time I used it my phone overheated like crazy with even slight use. Bit wary of it.
You could have just put the GS3 Touchwiz launcher that has been ported over and its as smooth as butter if that's what you want, this phone is smooth with any launcher other than Sense 4.
Best part using another launcher you get the sense look for menu's, contacts etc but get a nicer launcher.
Yeah, I'm using Nova Launcher (Apex is just as good though really) and it's perfectly smooth.
The juddering on Sense launcher is irritating. :mad:
Current home screen setup:
