I kind of figured that out in the first instance so didn't twig others might be confuzzled at first, thanks!
I have found a bug in SyncMe though, it bombs out with an error saying not enough resources on the server (PC) when it starts to transfer some large files. In my instance it always bombs out when copying over GTA3 game files. I imagine it has something to do with something filling up in memory and thus stops the transfer.
I did some investigation and found that it's something on the PC though because even ES File Explorer won't connect wirelessly to my PC until I've restarted my PC.
I'm using a Realtek onboard Gigabit network card so anyone else, and has GTA3 installed on one could you do a test with SyncMe to see if it can be replicated please?
My total transfer size for the sync was about 5GB and that was internal storage. It's not a problem in SyncMe I don't think unless SyncMe is sending over weird corrupted data that my PC is not able to make out and thus kills the network sharing abilities or something...perhaps.
	Disable scrolling cache?
I got no lag on or off though.
They're not expensive. In Lancaster, real tables cost £1 for 5 balls.Just downloaded this last night and have to say its pretty impressive but sucks that you have to buy the tables and they arent cheap either :/
. It happens on 0.1% percent of PCs though.I just tried it over 54G and the same, this time I tried the SD card though:
Hmm, clearing the net caches and ipconfig /release doesn't get the PC seen as a network share from the phone but restarting the PC does.
This must have something to do with the way packets are being handled by either side's network adapters I think or perhaps NIC drivers.
Investigation continues!
Sold my S2 to a friend, his old iPhone 4 would only ask for a passcode to unlock it after he had not used it for 30 minutes, anytime before then it just needed the button push to unlock.
He's asking if there is an app that does this for Android?
Not sire if It's HTC sense or ics but on my one s I can set the time for when thescreen locks in the security menu.
I can't on my Galaxy S3 and I don't remember being able to on the S2.
He wants to be able to push the power button to make the screen turn off, and for it to apply his lock screen after 30 minutes or so. Anytime before that pushing the power button just turns on the screen back on.
https://play.google.com/store/apps/details?id=de.j4velin.delayedlock2&feature=search_result
First result in the play store for "lockscreen timeout"![]()
Anything better that can do airplay or dlna?
