when will that be available ?
Offline maps is available with today's update.
They still provide no means to remove old devices and the listing of every single app you've ever installed. :/
Exactly.... I'm resorting to finding stuff I've posted in this thread to recall apps that I've installed![]()
 back @ you.
A list of over 300 apps, most of which weren't installed for more than a couple of minutes is so useful and easy to navigate, especially when you have to go back to the beginning every time you view one.back @ you.
Use Titanium Backup to keep the apps you've installed, or use software such as appbrain to save a list of what you have installed.
Huh, I was agreeing with you !![]()
Oh sorry, late night posting, I read it the wrong way!
Quick question related to apps (this was probably the best topic to put it in).
If I get a new Android phone, will I be able to get hold of all the apps that I had purchased on my Desire? Or would I have to buy them again? As far as I know, I won't be able to just take my SD card from my current Desire and plonk it into a new One X either, or am I wrong on that point?
Yes, you'll be able to download your previously purchased apps directly from the Play Store.
The One X doesn't have an SD card slot, so that might be difficult...![]()
 Will just have to transfer the stuff over via PC then
