Seems a little soft for glute work but that's where the foam roller comes in I guess.The stuff in the OP is good. I tend to just freestyle it these days, but from memory "5 way shoulder" is good.Ice I've been hammering my shoulder internal rotation and it's coming along nicely. I just wondered if there something you could recommend for the rest of my shoulder ROM? I don't do any external rotation stuff.
EPP, it will hurt a LOT at first but it's worth it.Just about to order the lacrosse ball...
But which roller should I get? The EVA or EPP one? It was recommended to get the EVA one previously in the thread...
My ball came today and I thought it was a bit soft but then used it on the upper back and a whole new world of pain was openedSeems a little soft for glute work but that's where the foam roller comes in I guess.
The one I bought is pretty cheap so I would go for that one.
Doesn't sound right, it should be completely solid with no hole.
