..and wing mirrors[TW]Fox;22286339 said:High gloss shadowline is the glossy trim on the doors.
..and wing mirrors
Yes, body coloured mirrors with a gloss shadow line lower section i.e the shadow[TW]Fox;22287815 said:Not on his car, the mirrors are bodycoloured.
Like I said, its the trim on the doors.
looked at 888s and ao48s but they were nearly £300 each, then came across these for £65 for a pair of new ones, so decided to give them a try, fitted them to the rear and immense grip was amazing, full throttle in first without a thought of wheelspin, since i didnt want to get loads of understeer around corners i got another set for the front.
Hi man, keen to hear what tyres at £32.50 each offer this sensational level of grip. Cheers.
Agreed, especially when the colour of his car is black anyway.[TW]Fox;22288174 said:Why are we even arguing about this?
.The guy has zero credibility, check his history. At best, if you exclusively believe him above everyone else, he has made all sorts of very terrible life choices combined with some very bad luck, at worst he is a known scammer, liar and all round horrible person (according to everyone else who has commented)
I'll let you decide which is more likely.
Anyway, now you know what the shadowline trim is (the black trim round the windows/B-pillar). Yours is glossy and mine is matt black. If you're M5 is becomming a track ****, how do you fancy doing a swap as I'd quite like the high gloss shadowline?
Then again you've fitted facelift bits and asked about nav/audio - are you keeping it straight?
[TW]Fox;22289612 said:You really don't - it tarnishes very easily and gets quite tatty without too much effort, sadly. I had it on the 335i and it was a pain. The Matt, by contrast, is easy to keep looking nice and suprisingly cheap to get hold of brand new replacement bits for if you want to replace bits.
. Know what you mean though - I hear it tarnishes easy, and I just replaced a B-pillar part on mine for only £15 brand new in the standard matt (which leaves me with the old one to rub down, paint and lacquer as a DIY high-gloss shadowline experiment).You definately want this though
E39 trim porn
. I'm a bit concerned, though, that if I take that first step I'll be consumed thereafter by an OCD desire to slowly convert the whole thing to complete leather
.Who knows what he's doing? It's all as bizarre as the RX7 thing was. Apparently he doesnt want to spend any money because its 'an old saloon' (He constantly reminds of this) yet if you look at his posts he's planning to do all sorts of random stuff including turbocharging it!?
[TW]Fox;22289814 said:Join the queue, next set of doorcards are MINE!!
I'd fit the M5 interior but whilst the drivers seat isn't brand new (But still fairly awesome) the passenger seat and rear seats are so good I just know I wont find another like it so I can't![]()
the land of fantasy no doubt.
