Official iPad (2012 model) Accessories Thread
I bought one today, off on hols end of the week so want something like I had on my old iPad 1
I just bought the incipio dark grey featherlight and dark grey smart cover costing me £65 after waiting and reading this thread and now they do this less than a week later.
how annoying!
Meh, I'll stick with my existing smart cover plus Belkin snap sheild secure, looks better than Apple's effort.
Typical of them though to bring this out when it should have been the original solution.
I've got the iPad 2 version and fits perfectly to my one. Let me know what you think of it once you've got it on your iPad. I've got the red leather smart cover with this and the contrast of colours looks pretty good imo :)
Yeah I got the one and it fit perfectly, combined mine with the black leader smart cover and it looked very good. The back cover is a bit slippy to hold though.
Unfortunately, I don't have an iPad at the moment, I had to send mine back because of dust under the screen! I think I'll send the case back as I wanted something more grippy to hold, not sure though as its very nice.
I got a smart cover and a belkin back cover for mine, works well. I do really like the look of the new apple one tho, might have to splash out on one next month as finally the white one doesn't look gray!
Just got my new smart case, love it!
Not specifically for the new iPad, but I bought a Cloth Addiction microfibre cloth today.
http://www.powerthreads.com/clothaddiction/
I cannot stress how lightly I touch this cloth to the screen and it removed a days worth of smudges (and those lines you get if you use a smart cover). Better than any microfibre cloth I have received with any products, or the ones you use for glasses.
rp2000
rp2000
Where did you get it?
What are the edges like on the new smart cover? I remember the original apple ipad cover had the same edges and it digged into your hand a bit after a while.
I really want a case that has a hand strap but I'm not spending £40 on a "branded" one. Any suggestions?
