- 24 Apr 2006
- SE England
And not at all addictive!![]()
I spent most of the weekend playing! Not addictive at all
Back on Thumb Keyboard, I just miss the landscape layout in it that other boards don't really have:
I'll be using it on my N7 as well
Looking forward to gamies like Dead Trigger on it too though. Good thing about rooting is that you can hotswap around application data easily.
I hope Google enable cloud based app data storage for game saves and whatnot, saves an extra process.
Look at what I found:
http://i.imgur.com/Lju9r.png
https://play.google.com/store/apps/details?id=com.calsto.statusbar.jb&feature=search_result
No need for root access etc. just install and you have the stock android JB black status bar straight away
Only problem is in order to get notifications, you have to grant access to pretty much everything so in other words it can access all your texts that you receive etc.![]()
It runs and looks just as good on the S3 too with ultra high settings unlocked
I just want to see it on the bigger screen!
Dead Trigger is awesome on the 7. Really shows off the power of the Tegra 3 chipset.
Thanks for the heads up, just bought the app and am impressed with the landscape layout. Really makes a difference with my sausage fingers![]()
The HD version won't break the bank.![]()
