Will get it done as soon as i can, keep an eye here and on the site for information (http://www.tftcentral.co.uk/)the DGM IPS-2701WPH has just arrived with me for a full review on TFTCentralWill get it done as soon as i can, keep an eye here and on the site for information (http://www.tftcentral.co.uk/)
have you accidentally turned the DCR feature on? check in the OSD menu
checked and nope - as I say it only does it when watching movies and it scales up and down the brightness like someone rocking a dimmer switch up and down every few minutes
I thought I'd gained a cataract at first!
Being that the panels are high end I take it this would be a good for colour accuracy and have a wide gamut?
Is this 120hz, couldn't see it on the initial specs? Also with the picture showing the DGM and the Dell in the middle, it appears the Dell produces far superior colour. You just have to look at the details on the light reflection on the floor which is more white than the DGM's blue. Maybe the DGM needs to be calibrated - I dunno.
to owners with this screen, do you find the aspect ratio control in the OSD menu (options for wide and 4:3) does anything? after testing at lower resolutions the setting seems to do nothing at all.....perhaps while this option is listed in the OSD menu, there isn't a scaler and so it cant control the aspect ratio
try running a 4:3 resolution for instance or use an external device which inputs something other than 16:9 aspect and see whether that control makes any difference?
no, its a 60Hz model and i wouldn't judge anything based on a photo when it comes to colours. They will always look different as well between this DGM and the Dell U2711 simply because the U2711 is a wide gamut screen and this is standard gamut
If the Dell U2711 was set to sRGB should the colours not look the same, I would have imagined that if you were viewing under Adobe RGB on the Dell that they would be different.
ok thanks for testing. it doesn't seem to work at all on the screen i'm testing here which is odd. If i choose for instance 1600 x 1200 input resolution then it auto fills the screen no matter what. Switching between 'wide' and '4:3' modes does nothing. I've also tried it from another PC and from an external TV tuner over HDMI and can't get the screen to control the aspect ratio at all. i can from my graphics card without a problem.
You are able to see a change simply by changing that control in the OSD and nothing else then?
