Spec me an LED Torch
Ill try and rephrase what I am looking for as it seems no one is interested putting a few suggestions forward.
A small (tactile I guess is the buzz word here) portable LED torch which is bright, has decent battery life and can be carried in the car for emergency uses. Budget is around £70.
If you're after small and a torch that uses common cells (i.e. AA batteries) then I'd reconmend a 4Sevens Quark Pro QPA.
http://www.flashaholics.co.uk/4sevens/foursevens-quark-pro-qpa.html
It's multi mode so you can have it bright or very low (10days run time on lowest setting)
£47.95
If you want brighter and longer run times and don't mind a longer light go for the 2xAA version @ £59.95.
The single AA light @ 108 ANSI lumens if still bright though - easily 10x a maglight.
Chuck an Energizer Lithium AA cell in it and leave it in your glove box indeffinately. Please don't use alkaline cells in it.
Can anyone recommend a bike light? Looking for something similar to the cree xml light that was doing the rounds about 6 months ago. It is to use on my road bike only. Budget is £30 - £50
sorry to resurrect but can anyone recommend a head-torch, its for an off road night run so needs to be reasonably powerful and last for about 2hrs (depending on how fit I am by the time I get to doing it...)
Been a while since i had the urge for a new light so just ordered this little 2000 lumen "monster" 3 x XM-L - 4 x 18650:
http://www.manafont.com/product_inf...00lumen-3mode-flashlight-golden-418650-p-9275
With 4 of these:
http://www.flashaholics.co.uk/batteries/ampmax-18650-3100.html
And a new charger:
http://www.flashaholics.co.uk/batteries/sysmax-intellicharge-i4.html
Strobe effect using cheap dropins. Noticed when I was shining inside my case and thought it looked pretty cool :p.
That's PWM (Pulse Width Modulation) in play - cheaper flashlights use it to modify brightness rather than the better and more efficient current limiting that better flashlights use. I think I've only got one PWM like left in my collection (Romisen RC-N3).
I haven't been in this thread for a while!
With 4 of these:
And a new charger:
Good choice! I also have a Skyray King winging it's way to me! It's a mammoth.
On the battery front I went for some Panasonic NCR18650 2900mAh cells. £5 each on the bay.
I've gone a bit silly again.
As well as a Skyray King I also have a Jetbeam PA40 and a the new light from Fenix, a Fenix LD41 heading towards me! Both the Jetbeam and the Fenix are 4xAA lights, a format that I find to strike a nice balance of running time and brightness, with a good physical size. My first Fenix!!
Nice going!
I thought that I was set for lights, with my LX2 Lumamax, Sunwayman V10R Ti and many many others, but when I found my Maratac AAA Cu again, I remembered that I need a "tiny-little-wee" light - So I bought a Maratac AA Aluminium.
Sometimes I don't want a light that's bigger than a finger, so a light that's barely bigger than a AA should be perfect! My old iTP Eos A2 was perfect until I dunked the head in a glass of whisky...
I've not seen that Fenix before, would be great to hear your thoughts on it when you get it.
