Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Its just the way you put things across, you put it as though all other brands can't take a photo, period.
You make it sound like D700's AF is so good that you never fails to take a photo with it and that if one even merely attempts to shoot one the outer points with a 5Dii the thing will instantaneously explode in your hand.
You make it sounds like D7000, D800's sensor is so good you can push and pull like a yo-yo with no consequence.
You make it sound like the Nikon system line up is so great that there are zero holes.
You make it sound like their lenses are so clear that the other manufacturers might as well give up.
More still, you make it sound like none of the other makes can do 1/100th of that and they might as well use a lego camera if not buy a Nikon.
You make it sound like that one shouldn't even consider anything else but Nikon.
You know, with that amazing AF that snaps in any situation, the ability to push and pull a photo at 5 stops, a resolution so great that you can crop like never before.
Who needs a photographer? Just point the D800 vaguely at the subject, ignore any exposure setting and hit the shutter. No doubt it'll hit focus, you can pull it back in post and crop it to perfect composition.
It is that good!
Sorry, that's the impression you give when you go on about Nikon.
(I might have exaggerated a little bit there but you get my drift)
It is that good!
