I make it less than £26-27 unless you are grossly over-paying for your leccy
shhh - I run a cable over his back garden and plug my system in - he hasn't noticed yet.!
+1, kind of
a single 680 can hold 60 FPS on ultra @1080
a single 670/680/7970 does suffer dips at 1440p though, with no AA it's fine, but I was dissapointed with the IQ of no AA so bought a 2nd 670 to go with my DGM 1440
Would it be a better option of going with a 4gb (670) card rather than a 2gb (670) or 3gb (Ati) card for 1440 res? Or go for a cheaper 2gb / 3gb and get another for sli later?
I don't have a maths degree, so the exact understanding of an electricity bill is beyond me.I make it less than £26-27 unless you are grossly over-paying for your leccy
However I have a rough idea that it's about 8p a minute off peak (11ish to 8ish) and then the first <insert random number> of daytime units are about 25p. After you use those it goes down, but I'm on my own and try to be pretty careful with my power use, so most of my peak use is in the 25p area.
my eyes are now drawn to it on any page with a white background.
has anyone opened and successfully removed this lump of clear plastic if your are going to mount it on a vesa swing arm
yes they have, it is well documented on the forum![]()
That is good to know any pictures.?
Got one of these for my brother last weekend, it has two stuck white pixels - is there any way to fix them or are with stuck with them? Presumably this is better than a dead (black) pixel in terms of being able to correct it?
What is OCUK's pixel returns policy (not DSR)?
Arrived today and loving it, but have a strange problem:
Monitor is blank during post and only "activates" once windows loads.
My guess is the monitor doesn't 640x400 used during post or bios?
Is there anyway of working around this?
Not being able to see bios (or safe mode presumably) is a little bit of an issue..
Use display port![]()
In thinking of getting a 27" WQHD monitor for gaming. What this monitor's input lag and response like in terms of FPS gaming? Good/ok/bearable/bad?
Also, is it worth taking the risk over splashing out on a U2711 instead?
Post 2k!![]()
