S3 or note 2?
life is just too complicated![]()
both are good, depends what you want tho
S3 or note 2?
S3 or note 2?
S3 or note 2?
Pretty easy decision really...
Are you comfortable with the size of the Note? If yes get that, if not get the S3!
...Not in my book it doesn't. For a given diagonal screen size, 16:10 provides more screen area. For example, the Note2 has only 2.4% larger screen area than the original note, whereas a 16:10 5.5" screen would have been 7.7% larger.
Then by that logic why not have a 1:1 screen? Your issue is with the size of the screen not the aspect ratio.
16:9 is the universal standard for virtually everything these days, what does 16:10 offer other than the "benefit" you're highlighted?
Better portrait website viewing for one thing. A less elongated phone for a better pocket fit.
I'm still not understanding why you think your opinion on screen ratio is somehow a universal truth? The original note was 16:10, and did quite well for itself.
There's rumoured to be a Nexus that's about the same size as the note 2. If it beats the Note 2 in the resolusion stakes then my attention will move towards that
