- 17 Oct 2005
- North of Watford Gap
Hi, I would have thought that if they fit a high downforce rear wing then that has to be balanced out with a complimentary front wing otherwise the car will understeer because the grip at the rear will be greater..
Chris
You would, but the front wing is less of an issue, drag wise, as the the air that would otherwise flow over the wing would end up hitting something anyway.
I doubt they have special rear wings for Spa anyway - I'd imagine most teams are using similar wings to Hungary, but just shallower depths. I have noticed most teams have adopted less complex front wings though - particularly standardish endplates have returned to some teams, rather than the myriad of curves other teams still have kept.
Most teams will have special Monza rear wings though - I guess the front wings will largely be the same as Spa, again just with shallower angles to find the right balance.
