Wonder what it'd cost Sim Free?
£450 - 500 is a safe bet.
If all my contacts are backed up to google contacts, will I be able to retrieve them using a windows phone? Worried I'll have to re enter all my contacts which would be rather time consuming![]()
Yup.
this is looking like my next phone. It's funny how the cyan phone hasn't been announced, yet, they have a wireless charging plate in cyan :sIm interested in wireless charging or rather peoples opinion of it.
Is it cool - yes
Is it a gimmick - not sure..
Meh "Last edited by Fillado; 12th Sep 2012 at 00:28."
How should I know.
I feel like I should dust off my Lumia 710 and play ARMED! with you what with all the back and forward
its a cleaner look as well, a small pad on your desk and you just lay it down, no cable ends randomly hanging about. Not having to seat the phone in the dock connection. Looking forward to Dock with built in NFC, then you just set it on then it syncs to you pc and charges with you having to do nothing.Maybe someone can convince me about wireless charging. I don't see how it's anything other than a gimmick?
What are the advantages? You still have to plug the charging base in. The phone goes on the base- it may as well just be plugged in as normal? Also, you're then stuck with only being able to recharge wherever the base is, although I'm sure you must still be able to charge the conventional way via micro USB for example.
I can only see it being useful when wireless charging is literally everywhere, e.g. built into desk tops, coffee tables, couches, car dashboards i.e. anywhere you might realistically put down a phone.
Am I being a little short sighted?
Wasn't even included in the editI feel like I should dust off my Lumia 710 and play ARMED! with you what with all the back and forward
After reading up on the Qi wireless charging standard Nokia uses I didn't realise it can actually provide 5 watts of power. Which is what most USB wall chargers provide (1A at 5V). Makes it far more usable than I first thought!
woo Tesco shopping app out now there taking noticeI cant wait to snap some pics with this handset
.... or if it is literally strictly within the boundaries of London and they block all the signal that leaves it's borders through a Dr Evil style plot![]()
