Anyone apart from Robbotempted to sell the S3 and buy the iphone 5?
Thought crossed my mind. I haven't done though. Probably get an iPod touch instead.
Believe it or not, there was a reason for asking but thanks for the condescension.
I noticed on the One X that certain CM ROMs all flashed over the device's WiFi MAC address, effectively giving all One X handsets with that ROM the same address.
Hence, if it's doing the same here, and he has MAC filtering on, the WiFI won't work.
I've tried flashing stock XXBLG8 through Odin, then flashed CM10. Still didn't work. I give up![]()
Why would I want a device with less functionality that doesn't even have a HD screen?
lets be honest.. the ppi is similar/higher on iphone than it is on s3.. so in the end its just numbers? you want a hd screen for clarity don't you? so iphone5 is a better screen in this case even tho it is smaller..![]()
Enigma, have you at any point flashed a Samsung JB Rom?
Smokedog, I'm at work at the moment so I'll try again later. Although I'm sure I flashed and wiped everything in that order.
1. Nandroid backup your PA rom
2. download stock XXLG8 4.0.4 ICS Stock Rom, Odin version
3. flash above mentioned ROM, it won't boot, will be stuck on samsung bootanimation, don't worry.
4. take out battery and reinsert it, put phone in Download mode, check phone bootloader update in Odin and flash same stock ICS Rom second time
5. again put phone to download mode, flash CF Root and go to CWM recovery and Wipe data/cache/dalvik
6. now boot into stock ICS 4.0.4 XXLG8 Rom
7. go to settings, more settings and enable NFC
8. reboot into CWM recovery and Nandroid restore your backup of PA Rom you made earlier
When you flash back to the ICS rom make sure you go through the setup process and connect to wifi AND NFC, ( I had the NFC problem and fixed it this way).
I followed this from the PA Thread on XDA to fix my problems...
Paranoid Android is where its at, make better use of that big screen
http://forum.xda-developers.com/showthread.php?t=1745003
PPI means nothing, quote screen resolution if you want to talk numbers.
