 - 19 Feb 2012
thats a nice stealth switch. good work there!
			Thanks Jamsames, pretty chuft with how it's turning out.thats a nice stealth switch. good work there!
 I need to figure out exactly where I need to place the piece to be cut, also the clamp is a bad combination with the mitre guide because the clamp has decent force to hold things in place but the mitre guide is an easy push over so throws it off whatever angle you set it at so I recognised this & fixed the angle & only clamped so it was touching & held it manually, helped do a straight cut & wow it blitzed through this 45mm pipe with 3.2mm thick walls, took about 3 seconds or less & safety glasses should be worn using this as chips fly everywhere, I will mod this tool at a later date for the clamp & guide combo to function better as well as add a marker for where it actually cuts.
Thanks RicochetAwesome workmanship.
 just need smoothing off on the drum sander now.
Thanks DiggsyYet again, awesome - your patience, creativity and skill seems to know no bounds![]()
 all this trying has really risen my old limits.
Tis trueawesome. its the little things that make it!
 thanks Jamsames.
 time to mod on.
 tiny update due to a fat chunk of idling but an update, been having to rediscover improvising & patience with not following a script now so the stabilisers are off lol.
 I also learnt the fist basic skill modders need when stepping up to electronics, soldering
 for keeping the wires numbered I prodded sharpie marker dots on them lol, either that or a lot of fun having to run them in sequence to find the right order after soldering which would make for messy wire work.
I'll be honest - I don't like the design (im just not a fan of spindly cut aways) however that fan controller is amazing. Those dials are excellent and unique, somehting to be proud of. Keep up the good work
- GP
 true though it is maybe a bit too different or just too busy for most even but still I wanted exactly that, something that makes me say wow when I see it from the thought of knowing I made it without aid of factory machines, only got a tiny bit of it fixed together & it's already having some of that effect on me so can't wait to see it altogether polished, brushed & anodised =) my future projects might be more pleasing to more people though, just wanted a 1 does all rig for my main personal rig to last a good bunch of years, I'll mostly be making rigs for other people after this, either presents, charity builds or commissioned builds or parts, this is a rig that leaves no reason to make another personal rig, unless I fancied making a desk case.
 So I have a choice of 2 flavours, think I'll go with the rounded bits because the heavily angular one might be a bit too difficult if not impossible with files lol, both will be but yeah, the rounded one should be a fraction easier, the upper side I'm not really concerned about, it's the underside which might prove to be really difficult with scoop files (don't know what the proper name for them are).
Thanks SneblotThis is looking amazing, can't wait for more updates
Thanks infernox, got a few more of those grills to make yet.Brilliant.
Love the fan grill for your psu.
) & are relatively easy to change the colours but not easy enough to change without some effort so plenty of testing will be done to find my favourite colour once it's whirling.
 that might well match OK water cooling, that's how I lose the plot, whatever failed me I make something far more awesome, I don't know why, I just do, maybe I need to get the gutted feeling away from me fast & this seems to work.
 was just aiming to make it an excellent update, the full HTPC & stand & spindicator whirling away & sweet custom all aluminium fan, oh well, next update.
Looks awesome, your creativity and designs are mind-blowing!
I looked through the Stealthlow project the other day and that was incredible, and looking through your work so far on this project, I'm totally mind blown, can't wait to see the finished project, such a clever and creative design you have for this.
Some times i amazed of how some people can be enthusiastic about the builds. Keep up the good work, cant wait for the finish. Defenitly will look awesome.
 Can understand that
 it all started with changing stock case fans & just spiraled out of control.
 Narrowed down from 120 lol reason for a couple of shots of each angle is to show how the light is shifting around.
