- 20 Jul 2004
- Dublin, Ireland
Will do.
The A-10 version you bought is the original Standalone version of A-10. DCS has since moved to a Modular system. So that instead of an install of DCS:-Warthog and another of DCS:-Black Shark and another of DCS:-Mustang etc etc. The Base program (DCS:-World) has modules of these aircraft installed into it.
This uses much much less disk space, takes much less to download, and ensures all modules are using the same code for Multiplayer compatibility and are all updated together. Plus you get a free Su-25T aircraft in DCS:-World too.
To use the latest version, you can leave your current version where it is, the new version will not affect it at all. Or you can uninstall it if you like, it no longer matters.
Step 1 - Download DCS:-World and install. (I recommend the torrent link at the bottom)
Step 2 - Download the A-10 Module for DCS World and install.
Step 3 - Fly.
Step 4 - Ask questions here or on the official forum (you will have many)
Nate
Step 3 - Fly.
Nate
