- 2 Nov 2007
n/a
CRT effect makes me sad, it's the first thing I disable when I flash Wannam.
Anyone else find that on the wanamlite rom the scrolling of widgets is jerky? Also the notification bar doesn't seem as snappy as ICS.
I'm going back to ICS, i agree that the home pages scroll more smoother but the widget menu is getting on my nerves lol
Where are the stock toggles - nothing seems to be linked on the intial post?
It's such a nice effect though and works so well.
No issues like that at all here.
Check post 3 of JB Domination for the 15 toggles addon for it
http://forum.xda-developers.com/showpost.php?p=27842073&postcount=3
SO when you go from homescreen straight into apps then into widgets and immediatly scroll across you have zero lag whatsoever?
Any suggestions for kernal on Wanamlite 3.9 or leave as it is? I dont have cwm which is kernal related i think.
As in the mciro sd card? you did choose flash zip in CWM recovery yep and then choose the top sd card option not internal sd card? The naming scheme sucks balls![]()
^ Can't believe how much that sped up my home button, never knew about it all this time. Urgh.
Are there any decent custom roms out that has hotspot working? bluetooth tethering is just too slow for me, and I use this every day at work!
I really don't want to go back to an official rom. ;(
Unfortunately no CM10 rom has wi-fi tethering working. Samsung Rom is currenty your only option.
I'm currently dual booting mine. Got paranoid android primary and Wanamlite as my secondary Rom.
