Think its because you have a custom rom. Kies is for official ones.
oh i have flashed back to stock from using a custom rom and i uses triangle away to reset the counter
maybe i have used the wrong firmware?
under build number i have IMM76D.I9300XXBLG8
Just flash it manually then.
3 UK ROM - http://www.hotfile.com/dl/176513786/4813ff1/I9300XXDLJ1_I9300H3GDLJ1_H3G.zip.html
3 Ireland ROM - http://www.hotfile.com/dl/176513526/89ea814/I9300XXDLJ1_I93003IEDLI2_3IE.zip.html
So, anyone with an unlocked handset on stock/non-custom ROM/FW tried plugging it in to KIES this morning and checking for updates?
On the software update I just got the message:
'Access to the software update service is provided to uses in the order in which they request it. Try later'
Anyone else had this? Used to just say 'no update'.
Thanks once I download that how do I install it
I've got it downloaded now, but dont know what to do next![]()
