Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
This is amazing, what would take 2 hours to download (updating OSX, 2.3G) now took 10 minutes !
(this is best way to sync it right?)
Not sure if you can, KIA is probably the best person to ask he knows an awful lot about network stuff....i might order this http://www.overclockers.co.uk/showproduct.php?prodid=NW-051-AS&groupid=46&catid=1595&subcat= heard it works great with infinity and also takes up one less power socket too then.
Just plug the WAN port into the LAN 1 port on the white box and configure the extreme with the Airport utility to use PPoE and the username (should be in this thread - I forget what it is) and jobs a goodun.
Raymond - the engineer would have fitted a data extension socket next to your wall socket for free - did you forget to ask for it?
Really want fiber now....
My exchange has been ready for a long time but when I put my number into the BT website it says I cant get it yet.......So I called BT and the guy reckons the cabinets still need to be done......I live soo close to the exchnage I cant belive the cabinet will be any closer.....
I wasn't home, my mum was over to "oversee" it as I was at work.
I didn't really know what the installation involved and had no idea I needed a power socket by the phone socket.
Even if I run a cat 5 to the Apple extreme, and take the BT hub that side of the room I still need 1 power socket for the white box.
Sigh.
Right, after 6 weekends in a row of no internet, and despite my good deal with Virgin, its time to move.
What is the best way to gauge ISPs in my area?
Buy a Draytec VDSL router then, no separate modem and router.
And replace the White box and BT Hub ?
You might have an exchange-only lin...on why I was syncing at 24.4MB on ADSL2......
You don't need the BT Hub if you're using your Extreme.
The Draytek can replace the modem and Hub/Extreme.
