- 15 Nov 2008
- Reading
haven't had much luck registering my serial number on the asus site.
Thanks for the 'heads up'!
I am not too sure though about the first qualification though, which says, and apparently only applies to: "Nexus 7 purchased by October 29th, 2012".
Are they trying to cut out folks who waited for the new 32 GB version, I wonder?
Edit: I have just checked... I ordered mine on the 30th which presumably means that I am excluded!
Edit 2: It looks as if they have to have been purchased from the Asus on-line shop also!![]()
My serial number on the Nexus status screen is not the same as the sticker / box
Worked in the end.
CSSN or SSN?
CSSN automatically identifies the device for me but doesn't work.
On the box. SSN works. (mine is 12 characters)
