Zefan, progress measured from "Just the bar to 110kg on squats" doesn't mean strength has increased, he may have just finally reached what he was capable of doing but started rather low.
Yup, I stalled on a few of those lifts & felt low on energy/weak/tired at times - also had to take a couple of short breaks (a couple of weeks) here & there due to work/travel commitments.Not really. If progress felt slow (which he indicated in his last post) then he should have upped weight 5kg each workout instead of 2.5. Even without this, going by SL 5x5's linear progression he should have reached the level he states in 3-4 months, not the 10 months he has quoted. Progress can only be slower than the set program if you stall, assuming he hasn't taken any real breaks then he must've been stalling = not strong enough.
It's definitely increased, but a large chunk of that progress will be natural ability (as you say) - I've never known what my 1RM is for any lifts (as I do my workouts in the garage alone, so my max lifts are all rep based) - it also meant I never really tested to see when I started - I just followed the progression advised by the 5x5 routine by starting low.Zefan, progress measured from "Just the bar to 110kg on squats" doesn't mean strength has increased, he may have just finally reached what he was capable of doing but started rather low.
It's my weakest lift & the one I stalled on first - so I feel you!.I started doing overhead presses yesterday and im dire at them , I can barely lift anything
my worst exercise by far. anyone else find this?
I was the same, but I've finally found a new setup prior to lifting and its working great so far.
What's your stance; Wide or Narrow?
snip
I'm firmly in the camp of cutting = no strength/mass increase.
Which is very true for advanced lifters that had very good diets/training regimes.
But for someone who just started going to the gym? Mass + losing weight can certainly happen.
I've experienced it myself and have seen it quite a few lifters who were on the heavy side. The more out of shape you are, the better it works. If we're talking about someone in his teens with tons of hormones still available naturally than it is even more obvious.
And it was nothing to do about technique, I am talking about basic machine/press/pull stuff. While neuro muscular connection does indeed improve, when the measuring tape says +1 inch on arms and -4 on waist I think it's very obvious.
So you didn't have a strength increase during your cut, you just found your testicles and decided to use them?![]()
Can you find yours anymore![]()
