- 10 May 2012
Modding can be a minefield to the inexperienced but here a few pointers:-
Use Nexus mod manager this adds the mod for you and when you remove it will replace any files the mod altered -http://skyrim.nexusmods.com/mods/modmanager/
To arrange your mods I suggest using BOSS - http://skyrim.nexusmods.com/mods/6 as nmm will not place the mods in the correct order
When adding texture packs add the large ones first ie skyrim hd or sro etc then add the other files over this - mod installing order is important .
Your game is seriously out of date check the integrity of your game files this should update the game to the current level. Check your steam settings as the game should update automatically.
There are lots of youtube vids to help you get started.
Hope this helps.
I'm new to modding,as well.
I'm using nexus mod manager at the moment.
I read about S.T.E.P on nexus,is that much better way of managing mods and the game itself?Seems to me it takes a lot of time to set this up.What are the benefits?(in long run)
Will I be all right if I just use nexus mod manager?or shall I download BOSS,to accomppany NMM??ta
