Given I rarely train chest I think i'd struggle like mad with 50's at the moment!
UE - taken your advice and stuck to BOR. Does feel more secure with the form. Stuck with 50kg and felt nice and 'easy'.
I think I do need to add more volume onto my main lifts, but sticking to the 5/3/1 routine at the moment.
Seeing some good progress at the moment. Seeing a lot of muscle being put on, which is awesome. Possibly the best I've looked even if I'm still a skinny &&&&er.
I just had a good shoulders session.
One thing though. Me and Shrugs just dont get on.
I try them fast, I try them slow.. I try em Heavy, I try em light...
I just never seem to get a good pump/burn from them that everyone else seems to. When I stand with no weights and shrug my shoulders I can engage them, yet when I introduce weight I seem to balls it up.
Im a weirdo
Remove forearms and replace with core.
Hi guys,
A friend has recommended an all body workout routine (mostly compound exercises). I'm currently in "fat loss mode". Because I'm new, I am unable to get through all the exercises (I'm dead by the time I get to deadlift). Is it wise to split it in two days (upper body vs. lower body) or just keep going until I build up me stamina?
DB Bench Press (compound)
DB Flies
DB Shoulder press (c)
DB Lateral raise
BB Bent-over-row (c)
Dumbbell row (c)
DB curls
DB/Triceps extension
Deadlift (c)
Seated leg press (c)
Leg curls
Calf raise
Leg Raise
Situps
like i say its nowt to do with grip its a way of conditioning yourself to engage the right muscles. Although gripping 50 or 60 k may seem trivial you are still having to squeeze the bar relatively hard. This automatically causes you to pull from the hands which engages the biceps first. if you use straps there is no need to grip the bar at all even a heavy bar can be held loosely. This engages a different motor pattern, one far more beneficial to your back, plus you will row more.
If you dont believe me test it out right now, close your eyes and get into a row position and squeeze your fists as tight as you can and pull a slow row motion, you will feel your biceps flex with lots of arm tension.
now do the same motion but have your palms open as if doing a press up, really spread your fingers and do a nice slow row, you should feel it between your shoulder blades.
It works trust me, once you get the patterning corrected you can get rid of straps for a bit if its bothering you as you will have the 'feel'.
Hi guys,
DB Flies
DB Lateral raise
Dumbbell row (c)
DB curls
Deadlift (c)
Leg curls
Calf raise
Leg Raise
Situps
All kinds of not good.Hi guys,
DB Flies
DB Lateral raise
Dumbbell row (c)
DB curls
Deadlift (c)
Leg curls
Calf raise
Leg Raise
Situps
That's the aim but am struggling to get through all of them. Tuesday I did 10 exercises, that was with 2 sets, between 6-12 reps. Some I did 3 sets.
