Do you have the game installed on a mechanical drive? Because I find this game runs better on a SSD, maybe that's what is letting you down.
I thought there was?
Urgh, so much modding! Really turning me off now, been at it all night. Bored now and don't fancy actually playing the game at all.
This is what's great about steam workshop.
Choose your mods. Click install, go do some stuff, come back later. All sorted.
kd
Does anyone have any idea why this game runs awful on my machine? Using Skyrim 2k HD Lite, running at 1440x900, everything on high but nothing on ultra, I've also limited the framerate to 35 and everytime I travel around the wilderness etc it stutters, just like it always had but I thought that was just due to my old processor (Bulldozer Fx-4100) but recently jumped to a 3570k. Now if a 480GTX can run Skyrim along with all those graphic mods, surely my 6850 with a 3570k can run Skyrim with nothing but Skyrim 2k HD Lite at a low rez?
Or is this game really this badly optimized?
.Anyone point me in right direction graphical mods would be cool and just addons that make the game better...
Cheers!
Skyrim's Creation Engine (Butchered Gamebryo) is a mess with regards as to how efficient it is, but hey this is Bugthesda we are talking about, there are a few things you can do to get it running more smoothly, two fairly recent mods that I would say for me are essential are ATTK SKSE Power Loader stops interference from Steam, generally makes the game smoother and skyrim configurator, this is an excellent tool to change your ini files, it makes it so much easier, you can change almost every aspect from shadow detail, ugrids, textures etc, so maybe in your case lowering some aspects will help, also if you are running HD texture packs, use either SMCO or Optimizer they will save you some precious vram, every little helps.
Hey you guys, I CBA reading through this whole thread so can I just ask, are there any basic tweaks that I can do to the .ini file or whatever which will make the game less jerky? I don't know if anyone else gets this but I find that my game is a bit jerky even though I can easily manage 60FPS constantly on my 7970.
Download 'FPS limiter' from nexus, and in your .ini files (which is documents/my games/skyrim), you have 2, skyrim.ini and skyrimprefs.ini.
You only need to do skyrim.ini for this. Find and change iPresentInterval=1 to iPresentInterval=0.
Save and load up the game.
Carefuly, if you don't install a fps limiter and your fps goes above 80fps. The physx goes nuts in this game. Pretty bad bug.
I have a dilemma with Skyrim at the moment, I want to use my SSD (only around 70~ GB left, so should be ok) so that I dont have to deal with the constant annoying stutter from HDD thrashing.
The dilemma of course is...do I reinstall with Steams official function onto my main drive or just use steam-mover...which has problems with mod managers from what i hear.
